CrackedDSM
- 5,833
- 5,734
- Dec 17, 2009
Pensacola,
Florida
Hey guys, I waited to make this thread after I reached the end of my rope. Well, reached that point today.
Quick background: 91 Talon TSI AWD. The gauge cluster will show lights, but the tachometer has never worked according to previous owner. It has a weird hybrid of 90 interior harness and 91 engine/chassis harness.
Attempted fixes:
1) Ran a wire from tach signal wire from ECU, directly to pin 11 (white wire) on the dash harness plug that plugs directly into the cluster. No tach still.
1a) Looked on back of gauge cluster and saw that the lead for "TACH" screw goes to pin 12 on dash harness, ran wire to pin 12 instead. No working tachometer.
2) Ran a wire from tach signal at ECU directly to screw on back of gauge cluster that says "Tach". No tachometer still.
3) Fully unplugged gauge cluster and kept fix #2 wired up, and ran a ground wire from ground to "GROUND" screw directly next to "TACH" screw on back of gauge cluster. Still no tachometer. Doesn't even flutter or twitch. Nothing.
I've searched and searched, and have no clue what the problem is. I am getting RPM signal at the ECU (duh), and it's the same exact wire I'm tapping into. It worked for a giant autometer ricer tach.
QUESTION OF THE THREAD:
How can I test the gauge cluster independent of the cars chassis harness and see if it's working? Is there even a way to do this without plugging the whole cluster into the dash harness? I'm honestly at my wits end. I really don't want to buy another gauge cluster, pop it in, and have the same exact issue so I'd really like to know if there's a way to test the cluster by itself.
As always, appreciate all the help fellas.
Attempted fixes:
