1G Gauge cluster setup
91-GS
1,390
66
Jan 12, 2013
Paris, Tennessee
Have seen few discussion threads with aftermarket gauges in stock gauge panel. Here are couple of examples:
Aftermarket gauges in 1G cluster
Mounting aftermarket gauges in 1G cluster
Have posted a similar thread trying to figure out what all is needed for a non-turbo car:
(Un)nesessary gauges
There is also another thread that i was not able to find again where a fellow moved stock fuel level gauge to stock boost gauge location. Was a pretty crude fabrication but a great idea.
Is it possible to use a turbo tach w/boost gauge in a non-turbo cluster and recalibrate/mod both so that tachometer is showing correct RPM and stock boost gauge is now a fuel level gauge? The face of gauge will need to be re-designed, but that won't be a problem.
An example of how it might look like, original image came from here:
