1G T-Case Drain Plug Gasket??
tsi1991awd
1,366
6
Sep 28, 2008
Puyallup, Washington
Is there a gasket that goes on the transfer case drain plug? Fluid is leaking out from the drain plug area....same with my rear diff. I have had the fluid changed twice since I have had the car...no idea if there is supposed to be a gasket???
Yes, there is.
Transfer case drain plug gasket - MD000312
Rear diff drain plug gasket - MB001294
Thanks bro, you always have part numbers for just about everything. Do you know if those parts fit the 1g?
Yes, there is.
Transfer case drain plug gasket - MD000312 (18.2mm)
Rear diff drain plug gasket - MB001294 (18.2mm)
While we are at it.
As far as I can tell these are all crush washers and the same 1g and 2g except for the diff fill.
Transfer case fill plug gasket - MF660036 (16mm)
Manual Transmission drain plug gasket - MD000312 (18.2mm)
Manual Transmission fill plug gasket - MF660036 (16mm)
Automatic Transmission case drain plug gasket - MD000312 (18.2mm)
Automatic Transmission pan drain plug gasket - MD050317 (14mm)
Rear diff fill plug gasket - MF660066 (16mm) changed 1994.10.1 to MF660036
