Front case gasket
NOSLO2PT0
2,686
250
Aug 31, 2002
Joliet, Illinois
I thought I had a 7 bolt gasket since the previous owner supplied one when I bought the car. OEM Mitsu packaging/label indicated it was for a 7 bolt. However, a lot of the oil passage holes didn’t line up.
Ordered a Victor Seinz front case gasket kit from Oreilly’s ( came with gasket, seals, and pickup tube gasket). The oil passage holes line up ok, but the channels seem to be missing. Is this ok? Been forever since I installed one of these.
Do those line up ok on the block Mike?
If you are out of town, I would order up an OEM from JNZ. Josh will have it to you before you get home, and Mike, I agree with Tony on this particular gasket. I like OEM over FelPro or VH for that one.. :)
I didn't use this "test" pump for a 6 bolt but you had my interest peaked so I went and put the gasket on it. Mine looks like yours so that gasket is probably the correct one but I do prefer OEM for the front case.
Here's a picture.
