T-70 bb Supporting mods suggestions
Status
Not open for further replies.
Slippi84 said:
squeak10686 said:
AuntiesTSI said:
WTF ARE YOU TALKIN ABOUT!!!!WTF Did you just have a monolouge conversation with yourself in a thread??? All I know is that true you learn more from losing then winning but I think in your caser it was shit you should have already known. 28.438373937 or w/e psi you clained was actualy run instead of 30psi on a huge turbo with a 7 bolt trying to make 500hp and blowing up should have been a jump hop skip away from a given.
Andrew ===>:beatentodeath: <===andrew's car
And wtf kinda mod list is that to go 10's WTF . I could do 9's with that setup shit tens should be doable on pump gas and a shitty tune by your grandma whose now def dumb and blind. EMS...75mm tb...$1200 fmic I don't know about you but that seems like a huge waste of money to me. You don't need to touch the head to go 10's at most I would recommend port matching the exhaust side or slighty opening it up. COP with MSD DIS-2 you think thats a tad bit overkill for ignition on a 10 second car?? How bout a good set of wires and some bpr7 or 8es. Aeromotive fuel rail??? Best of all the 2100 dollar clutch ROFL . That's a slap in the face to all the guys that have gone 10's with a act26 or 2900.
You want a serious list by someone not tryin to talk you out of makin your car this way here. And to prove a point I'll use the ass rapers at pricing SBR to even overestimate ads you can get most of this cheaper:
Engine:
2.0L DSM Manley H-Beam and Ross Piston Combo: $736
ARP Heah studs and MLS HG: $180(if you want to go extra you can get rod bolts from ARP for $45)
HKS 272 cams: $500
Prothane Mounts: $90
Install: anywhere from 2-3k(But this will include a lot of other things as well like timing and what not. This is where you will save your money the most if you have a friend or know how to do it yourself)
Fuel:
Walbro 255hp: $100
1000cc FIC's: $364
Areomotive AFPR: $152
-6an feed lines: $100
Turbo+IC:
GT35r setup for external with to4s cover(or in your case a Huge as T70): $1400
38 or 40mm external HKS: $415(If you pay anywhere close to this kill yourself cause a 40 can be had for 200 tops on tuners)
EBAY(YES EBAY FMIC): $250 shipped
Piping and couplers (doesn't really matter what kind or where as long as it's 2.5 and not paper thin): $400
Transmission:
ONe stop to a company called Dogboxracing @ Dogboxracing.com: $1200(You send them your trans and $1200 bucs, I'm not sure about shipping, You get a Shep quality trans back)
Tuning:
DSMlink and a eprom ECU: $700(I'm on the dsmlink forums if you doubt that you can get it for this I will prove you wrong fast)
Wideband O2: $300( I'm so far away from the other guys estimates I threw this in there just cause I could)
GUess what ladies and gentleman with the exception of small stuff that We will alow for a nother $1500 bucs that's it bring the grand total to $8200 we'll say $300 for shipping to make it an even $8500 . That's only $3500 more than his 5k and again that is with ass raper pricing. If you think you need more to go fast just hit up the 1/4 mile list and take a look at people going 10.6-10.9. The only thing that will swing this night and day higher then where it is is if you do suspension. :rocks:
Yeah maybe you could hit his budget if you knew how to do all that sh*t but chances are he doesnt... Even read the FAQ runnin tens aint cheap... yeah the kid could go ten's with what you spent but how reliable will that be? That ebay intercooler... JUNK how well do you think those welds are? I wouldnt trust those welds for DICK! And as far as tune "on pump gas and a shitty tune by your grandma whose now def dumb and blind" I dont care if that sarcasm but a tune MAKES a car... you aint runnin no tens with a bunk ass tune thats for damn sure... Either way I was just trying to give him an idea of what he would need as far as parts who gives 2 shits about prices... Some one could go tens with a junk yard car and all used parts and a stock head...and only spend 5k total in parts. I'd rather pay for quality parts over junk anyday.
MyBeatGSX said:
How about a manifold? A BOV? A dump tube for the wastegate. Rewire for the fuel pump. A clutch. A turbo back exhaust. An intake. Plugs. Wires. Bone stock ignition won't do 500+hp, so add a DIS-2. At least some new shocks. Gona need a radiator if he wants to drive anywhere other than the track, add a Fluidyne. Repairs on the car (master/slave cylinders are common, boost leak fixes, water pump, oil pump, alt., thermostat, etc). Oil feed and return lines for the turbo. Coolant lines for the turbo. What about safety equipment? A roll cage? At least some harnesses and good seats. He's going to need wider rims and at least some high performance tires, if not slicks. Brakes? 500hp needs to stop too. Boost, oil pressure, EGT, water temp, and fuel pressure gauges at the minimum. And most importantly of all TUNING TIME!! Its going to cost a small fortune for him to get that all dyno tuned. Because you know full well he can't do it himself.
Then the first time down the track something will break. There's more money right there.
I think YOUR estimate is even further off. People tend to forget all the small or supporting parts costs that add up to more than the big stuff. He'd be wise to plan his budget at at least $15,000.
Who told you need dis 2 to make over 500Hp???? Racing seats and haeness's u serious man. I have gone threw this same type of build I don't need to be told about small stuff why u think I threw in 1500 and used sbr pricing and rounded everything up. You guys are throwin in things that make it easier but they are not neccessities. The one thing I did forget is a ACT2900 or a clutch similar to it so just for shits and gigles well say 10K for a complete everything you NEED to go 10's if your an everday guy(I say that cause qe all know some people have freak cars that go like 10's with 14b and tuning or w/e)
HAHAHAHHAHAHA what a JOKE
So your telling me if I spend 1,000 more on my car it can run 10s?!!!!!! I have around 7,000 into this car right now and its not going 10s.
Your forum bench racing a very sad out look on how to build a car, I spend a little over 7k on parts, rember THINGS BREAK. Things need to be replaced, OEM parts arent cheap. Doing things the correct way isnt cheap.
Since most HACKs think its so easy then why arent you in the 10s yet, I love those people.
Well My car isnt tuned but the car should do 11s, LOL you know what im talking about. those IT SHOULD DO THIS kind of people. I see forsale adds all the time, "capable of 10s" "Should run 11s". To many dreamers have fun and good day.[/QUOTE]
you sound like a "I bought everything why aren't I fast guy" I didn't say 1500 bucs will take you anywhere that was money for little stuff like gaskets and stock stuff that might break or w/e. If you think that your car not having a goo tune isn't why you aren't going fast enough u are clueless. I am not in the 10's because i'm gettin my ecu fixed by tom @ dsmlink but once it gets back I'm gonna go put up the number to back up my build.
Let me go strip my car to nothing but a bare chassis, engine, and steering wheel. Maybe I'll even rig up a cardboard box for me to sit on, just for comfort and some bling factor. That's really all I need to do to turn 10's and it will be FREE.... except for that box...:rolleyes: :rolleyes:
Like PSI NRG and JOEY both hit on, you can hack your way into the tens or you can do it right and make a reliable, solid 10 second car.
Who's using a BONE stock ignition in their 500+hp car? No one I know.
Status
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
  • Wanted 4G63 800cc injectors
    Im looking for a set of injectors that are at least 800cc. Thanks!
    • DSM_Thorpe
  • For sale 2g 2g rear brace arms
    2g rear subframe brace arms. Missing one of the bushing spacers. No rust. Had someone looking...
  • For sale 1g 1GB Eclipse Tail Lights
    1GB Eclipse Tail Lights $80 + shipping and paypal fees* not flawless but in very good shape...
