2G FP Red - Supporting mods.
chicagoboostin
290
3
Mar 20, 2004
Chicago, Illinois
well i have gottena brand new FP red sent to me from fp, i didnt want the fp red, i actually ordered the fp green but since they said there going to be on back order for a long time, they send me an fp red for no extra charge.
I am kind of worried its to much for my set up.
i have
750 injectors,255 Fuel pump,DSMLink,Water Injection
FMIC,1g big rods,2g pistons,Fresh Rebuilt Motor,"Stage 3"
Race Head,38 MM External Wastegate,gm mas, FP2 Cams.
i feel like my rod/piston setup isnt enough for the fp red for higher boost levels.
what would an adiquate boost level be for my set up?
Your set up is fine but depending if you want to try and get the most out of your turbo your engine internals might be your weak point.
some have laughed at me for saying this but i really only wanted to run 12's maybe 11's.
they said my turbo is overkill for those times. i lan on running 10-15 lbs daily and 15-20 race. never above 20 until i get my internals set up. (15-20 race gas only) realistic?
Yes that turbo is over kill for your goals seeing how it has been in the 9's. Your engine will support the boost you want to run but to take full advantage of your turbo you are going to want to run 25+ psi.
