1G Big 16g supporting mods
lzertrbo
125
Jun 22, 2009
spanish fork, Utah
ok so i am getting a big 16g and i would like to know what supporting mods i need to do if i am going to run 12-14 psi or more, and what do i look for to make sure its a big 16g
The Big 16G doesn't really start moving air until the boost level climbs. At 10-12psi, a 14B's airflow almost mimics that of a Big 16G because of a faster shaft speed and a completely different compressor efficiency. If you're buying a Big 16G to run 12psi you're better off with the stock 14B.
Now 17-18psi is a different story....the Big 16G is really moving some air at that boost level. I'd be concerned for my fuel system with anything beyond 15psi.
