pagosa dsm
- 509
- 131
- May 7, 2005
pagosa springs,
Colorado
Has anybody made or bought polyurethane bushings for a 1st g steering rack?
)maybe I should swap those right now...So you are saying that they're available somewhere? I've had no luck finding them.
Or could that be one of the few interchangeable bits that 3S's and DSM's share?
Since my car is guarding some of my jackstand collection again, (transmission died)maybe I should swap those right now...
Seriously, it's happened.
What's the possibility of removing the stock ones and having someone mill some Delrin replacements since the car is floating on jack stands?
I agree. I replaced the rack bushings on my Laser a few months ago and took a close look at it. Lateral play is held in check with very little rubber, about 3 to 5mm. Then again, how much movement does it take to cause steering vagueness?Well, curiosity got the best of me. Just looked at the rack bushings and really, the one that controls lateral movement is so thin, that actual deflection is probably negligable.
I'd aluminum bushing or rod-end everything but I'd get dinged for a bunch of points with NASA (for good reasons). Non-metallic is free, so that's what I'm exploring.
Hayfever....yeah I got it right now....and I'm all out of Claritin.
There are so many other "soft spots" to look at, I believe the rack bushings, unless they are deteriorated, are one of the last things we need to focus on. That doesn't mean I won't be making plastic ones this winter however.I agree. I replaced the rack bushings on my Laser a few months ago and took a close look at it. Lateral play is held in check with very little rubber, about 3 to 5mm. Then again, how much movement does it take to cause steering vagueness?
