Starting issues - No / Doesn't / Won't Start - MERGED
prodsm
258
Nov 12, 2002
canada,
All "my car won't start" discussion threads are merged HERE. We've basically made it easier for those who insist upon not searching by grouping together all threads from those with similar issues so you can just scroll through and see some possible solutions. To search for info within this thread, use the "Search This Thread" feature in the black bar about 3" above what you're reading right now.
Could be anything from a loose battery terminal to internal engine damage, and literally everything in between which may involve the electrical, fuel, and ignition system...possibly even something that you screwed up while working on the car yourself. While it's unlikely we're going to diagnose and solve your problem over the internet, feel free to discuss any possible solutions.
I live in Canada and right now its not very warm out, about -30c
my car does not have a block heater too keep it warm.
I tryed to start my car this morning and it wouldent start, ive had this problem before but this time, the car doesnt crank at all it just makes a sound that sounds like an electric drill.
Whats wrong.
Thanks
Did you replaced the fuse yet?
If your stalling, and then the car won't crank, but you can bump start it, it sound to me like a flooding issue. Check fuel pressure, and then have your injectors tested. They could be leaking or getting stuck open.
Car went down a few weeks ago for new clutch. While I was waiting for it to be made I went ahead installed my JMF SMIM and 272 cams. Get it all together and no start. If I add in 50* of cranking advance I can get it to start but idles like the timing is off. I checked and rechecked and rechecked the timing and always dead on. I have fuel, spark, CAS is not 180 out. IAT, coolant and MAP sensors are all working. Compression tested at 160-165 across all 4.
Now, when it did run, idle was horrible. A/F was in the 12-13 range. I pulled the plugs multiple times and they would be soaked with fuel. I even went so far as to pull the cams back out and replace them with the stock cams.
Im out of ideas and getting frustrated. Im usually able to diag and fix things myself and dont usually ask for help so this is a rare occasion. Also, Ive had my hand in a cast for the last month and still able to do all this work. :hellyeah:
Has nothing to do with fuel or spark..
Problem was: Coolant Temp Sensor.. I disconnected it and it drives fine.. still have to diagnose why this sensor causes this..
BUT resolved. as all my other problems i make sure to resolve them and let you all know
there are 6 threads that talk about this,,,,,,, ....6 threads were everyone is so eager to help, that links are posted in attempt's to resolve the issue,.. i would not not be doing this thread. if i still wasn't looking for an answer, ...SO i decided to DRAW what i have done,,, so i dont get the several links, i have already been sent, im hoping you might find something in my set up i cant figure out,,,,,
with a black top CAS. and a 98 STOCK ECU. i can get the engine running. BUT IT WILL DIE AND IT WONT FIRE BACK ON Until I ADJUST THE CAS EXCESSIVELY...
with a 96 DSM LINK V3 FULLY TESTED. i CANNOT GET THE ENGINE ON AT ALL!!
1.base timing is dead on.
2.1st cylinder TDC. CAM GEAR TICKS ALIGNED!!.
3."were is this ECU FUSE AT ?????? that magnus sport talks about ? does it exist?
4.YES battery was unplugged.......
with the firing order swapped.... WHY does it take it soooooo long too turn on,and why wont it turn back on after it is turned off?
why wont the chipped ecu work?
what could cause this. ? is it the CAS. the CAS HARNESS? Which is professionally done!
will going to a 6 bolt head solve this issue?
will a Kingsley censor SOLVE this issue ?
AND MOST IMPORTANT HAS ANYONE ANYONE ACTUALLY DONE THE SWAP AND SOLVED THE ISSUE. the other members with similar issues dont respond telling how they solved it ? sooooo. that is why i write. ""remember, i have seen every video. and link soo. what else could it be? "
1234
hum this is the way the spark plugs are set. i must of drew it wrong.. but can some please simplify what 180 means on the cas.... it's like being told something so many times that you can repeat it perfectly. but you don't really know what it is,, what is it ? what does that mean 180 out ? ... and isnt that pic of the CAS that says 180 out,,, and tdc ? shouldnt it be, rotated to the left. shouldnt it line up perfectly with the indentations of the cam ? my intake cam makes a straight line 3:00 and 9:00 when the cam gears are at the 3:00 and the 9:00, so shouldnt the cass also be at the straight line, that's how it plugs into the head. ?
I wasn't sure where to post this so please correct me if im wrong. Well I went out to start my car last night to let it run and keep some charge in the battery as I live in ohio and its getting cold out here. I tried starting it up last night and it took forever for it to start. And when it did finally start it shot a fireball out the exhast. The only thing Im not 100% on is the fiav on the bottom of the throttle body. I don't have coolant lines hooked up to it at the moment but it is plugged in. I know that the 2g maf that's on my car will make me run a little rich. I've also got the stock injectors in it right now to be able to move it while I save up to get link or something equivalent. To tune the 780cc injectors. The safc is zerod out as well. My question is could not having coolant lines on that fiav cause me to run soo rich its hard to start?
The FIAV not having any coolant lines should not make it run rich. And the 2g mas actually makes your car run lean, not rich. When you run a 2g mas with stock injectors your SAFC settings should be somewhere around +20% to make up for the extra counts of air with the 2g mas. That's why 550cc injectors work pretty well for some people with no SAFC while using the 2g mas, because they are approximately 20% larger than the 450cc injectors, therefore it is almost balanced out. If you had 550cc injectors you could leave the SAFC around zero and if you had 660cc injectors you would have the SAFC set to approximately -20%. Make sense?
If I were you I would check the coolant temp sensor. Sometimes they can be bad and give your ecu a false temperature reading. They like to default to like -20 degrees when they go bad which tells the computer that it is really cold out, therefore causing the car to add way too much fuel and exhibit the condition you are describing when starting.
These should be the resistance values for you to check the resistance of the coolant temp sensor. If the resistance matches the temperature your sensor is okay.
32* - 5900 ohms
68* - 3500 ohms
104* - 2700 ohms
176* 300 ohm
Here's a good picture of which where the coolant temp sensor is. Good luck!:thumb:
http://www.dsmtuners.com/forums/new...nt-temp-sensor-plug-picture.html#post50465875
Well, I have a bad feeling about this one.
To try to make a long story short, I've been down this no start road waaaay too many times with this car. I just finished up a build this summer (mods are listed in profile.) I've had issues with the 95 style cam sensor, so I just switched to the 1g CAS.
After the 1g CAS install, she fired right up! The motor was misfiring (kind of sounded like a subaru) and I narrowed it down to the injector for cylinder 2. When I unplugged it while running, there was no change.
Soo, I was getting ready to shut the car down to do some research, but it shut itself off instead. It was an abrupt stop. I immediately thought timing belt, but the belt still had tension and the timing marks appeared to be on.
When i tried to start it up again this is what happened:
uh oh. - YouTube
Any ideas?:hmm:
Sounds like your starter was grinding there at the end. Might want to take it off and check the teeth and make sure they are grabbing.
It also seems like it's turning rather slow. Is it getting enough power?
I'm at work so I didn't see it with any sound.
And I think that when you switch to the 1g CAS you are supposed to switch 2 and 3 plug wires, but I'm not sure..
How long has the motor been up and running? and how much of an abrupt stop was it? If it's turning that slow with a charged battery than there is something wrong internally.
When I've have an injector go out, I haven't been able to hear the difference, and only feel it above idle.
So in my experience it doesn't sound like a subaru.
I'm guessing you incorrectly swapped into a 1g CAS and that changed your ignition timing, it at least wasn't timed properly, and it may have messed something up internally.
I made sure to follow the proper steps to switch to the 1g CAS. I changed the firing order, and the injector firing order.
The motor has about 200 miles on it. I just did the timing belt after pulling off the old crank sensor.
I'm sure everything was installed correctly with the 1g CAS, because besides that one injector, the motor seemed to idle smoothly, until the abrupt stall.
I'm going to check for spark tonight, and then double check all my timing marks. I have a weird feeling that it's coil related. I'm just not 100% sure on how to test it.
Also, is there a way to test the starter while its still on the car? It seems weird that I would have multiple issues simultaneously, but I guess I've seen weirder with this DSM. LOL
