2G Sensor relocation question
DsmKhan
5+ Year Contributor
216
6
Dec 3, 2017
East Hartford, Connecticut
I just installed a ohm racing harness in my 99 gsx. The injector resistor connector is now inside the car as well as the ignition sensor. Question is they both where grounded in the engine bay, well they need to be grounded inside the car. Does anyone have experience in this matter??????
Honestly any bolt that goes to your chassis will work fine. Just make sure you sand down any paint so it gets good connection. I just did my fuel pump rewire and grounded my relay to one of the large bolts that holds the upper rear seats down. Look for any appropriate size bolt for the wire, sand and ground it.
