bstaley
- 73
- 3
- Jun 2, 2011
Okemos,
Michigan
So I'm in the process of pulling the motor/trans in my 2g awd. While removing the electrical clips I pulled the injectors. I had just cleaned the whole engine bay in the beginning of summer. Though, when I pulled the fuel rail I noticed it was dirty around the injectors. Sand could have fell in, not a 100% sure. Stuffed the holes with shop towels and blew the whole top of with air. I hope I'm just be neurotic, but I don't want to do all of this work and have it jack the head or cylinders up. If any sand did fall in it was less than a pinch. My plan is to run a scope in to try to get some more info. If the valves are open it could have fell into the cylinder. I could use any helpful suggestions on removing it or making it less of a threat.
. Oh well, I'd rather have it done right then just turning a blind eye. Thanks for your suggestions!
I also found out that I have a few bolts that have turned to glass. The lightest turn of them snaps them off.
