Injector "fell asleep"
B00st LEE
Dec 2, 2008
Charlotte, North Carolina
hey wats up fellow dsmers
Just bought my 2nd dsm 1g 93 talon tsi
the first night out with the car, boosting well over 15 pounds
mods are evo 3 16g, wally 255, full exhaust, stock injectors.
Long story short car started over heating and dropped a cylinder (number 1).
Tons of white smoke coming out of exhaust while it was hot.
I shut it down for a while and limped it home on 3 cylinders.
Popped open the rad cap and nothing but steam. Threw some water in.
Woke up this morning started it up and it was still running on 3. All cylinders getting spark. I started plugging the boots off the plug while car was running. Started pulling injectors and rpms did not change when i unplug number 1.
My question is, is it possible that the injector failed then caused me to overheat, and if so what steps should i take for this repair. (head gasket). Or should i change that injector and see what happens. Any info would be a great help thanks.
White smoke = coolant. You probably lifted the head gasket, it overheated, and now your head may be warped. You need to pull the head and have it pressure checked and flatness tested. Time to start budgeting for a full rebuild since you might as well change the belts and pumps while the heads off.
Thanks for the input guys. Will keep you updated on the progress of the build. As for now the plans are to pull the head off new 3 layers mtsu head gasket. Machine the head, hot tank and port. Slap it back togather and hope for the best.
