?s for BW S256 users
Artago
2,094
31
Nov 30, 2006
North Vancouver, BC, Canada
Hey, the HP charts don't let you search for BW S256 users and I wanted to ask a few questions.
1. How much HP, TQ, LBS/Min, PSI and Octane are you running?
2. What kind of spool at you getting?
3. Do you have DSMlink logs you can post? (maybe from the dyno pull)
I have a BW S256 Non-ETT and I was wondering what kind of numbers are you seeing.
First hand experience only please.
Thanks
I am currently installing one but ett. From all the research ive done, should see mid to lower 50/lbs range with full spool around 3800_4000 depending on displacement. Sure justin will chime in if im wrong.
You can check out my dyno graph in my profile. I was on a s256 with extended tips and E85. Dyno was Dave Buschur's mustang dyno. If you have any questions pm me and I would be glad to help.
Thanks for the link but that's a S259 running ethanol. I was hoping to see some stats from pump gas S256 users. Looks like it's not a very popular turbo.
Sorry, since i get it out of the pump next to the 87/89/91 grades I condeider E85 pump gas.. By the very definition it is, just has a different main ingredient :D
Hey Artago, which turbine housing are you running?
Have not run into many people with the non-extended tip S200sx-56
I had a s200sx-59ETT in a variety of housings, and if youd find it handy Id be happy to share some of those results.
Awesome, thanks! Do you you have a dyno log by any chance?
No need to apologize, I appreciate any/all info I can get. I'm up in Canada and the only fuel options we have are 87/89/91/92/94 but no E85 sadly :( so I use 94.
I'm running the DSM flange housing. I believe .55 A/R.
This one: https://www.extremepsi.com/store/product.php?productid=21860&cat=263&page=3 but with a DSM housing.
Please do share what you have regarding any results.
