Colt4G63 also
- 3,389
- 61
- Jul 23, 2008
Tonawanda,
New York
It may be half assed, but I can't see how two regulators would conflict with each other. The return line on the front regulator is blocked off, so it can't affect anything.
What you need to do, is use the regulator that the ECU was designed to work with. Returnless systems have constant pressure, and systems with a vacuum hose on the regulator vary the fuel pressure based on engine load.
). I have owned two 96's and both have had the fpr in the rear (yeah, that oughta be proof enough
Whatever system you have on your car is the system you have. Your ECU doesn't care either way. If you have an fpr on the rail and the system is set-up properly, then that will work fine. If you have the fpr in back and the rail is correct, that will work properly.
