t25fury
- 121
- 1
- Oct 7, 2006
Houston,
Texas
copper spray can stand on both sides of the fence,usually its preference of the builder.Some swear by it, others have done just fine without it. As for the mls, yes you have to have a perfectly flat surface on the block and head to have a proper seal, as an mls gasket is not as forgiving as a composite one.IF you've installed an mls before without machining the surfaces and had no issues then I would say you got lucky and already had a nice flat surface.Personally I would not take a gamble on it as you may end up doing the job twice once you turn the boost up,machine those surfaces for an mls !
