Replacing a 2G Euro ECU with a 1G ECU
Conqeror
Jul 31, 2021
Europe
Hi,
I have a Mitsubishi Eclipse 2G Euro and I have an ECU for 3 cubes (normally I know it is for 4). Is it possible to connect the ECU with 1G?
The engine is 4g63 and has a camshaft position sensor on the camshaft sprocket.
I thought this was a temporary option and that somehow it would work.
Well, I have such an ECU for 4 cubes (photos). However, I do not have the keys for them, is it possible to get around the Immobilizer?
Even if you could bypass the immobilizer, you would definitely have to convert the installation to 4 ECU cubes. And here a diagram would come in handy ...
Does anyone have a schematic for my 3 cube computer?
If you are thinking to use a 1G 3 plug ECU as PnP, then you can't connect as PnP. The shape of those 3 plugs for ECU are totally different. I could be wrong but if my memory serves me well, EDM 2G 3 plug ECU's plugs are the same as the early EVO or RVR HSG/SSG. So you may be able to "connect" those ECU as PnP, but I believe it would require some works (includes tuning) to make it functioned since there are some differences.
