2G Manual ECU with auto wiring harness
Donv
5+ Year Contributor
51
6
Jun 11, 2021
Parkville, Missouri
I have a 95 GSX manual EPROM ECU with a 95 auto engine and fuse box wiring harnesses.
Will it run fine or not?
Manual ECU works on both. If it’s a factory auto car has a TCU anyways for the trans. Manual and auto engines used the same injectors.
Only the 1g the auto had smaller turbo and injectors. Have owned both.
I understand. So would everything be fine ?
Do I have to bypass anything, I was thinking it wouldn’t run because ones manual and another is auto
It’s a 95 GST harness
