Auto to manual swap...help wiring 2 step
jongreene
484
6
Nov 3, 2005
midland, Michigan
Ive searched numerous threads and cant seem to find a definite answer.
I did the automatic to manual swap in m 92 awd, and now id like to get my NLTS and stutterbox working, (keydiver stg3 chip). I am aware of the wiring procedure on the manual cars but clearly the autos are different.
I have the switch on my pedal assembly but cant find the connector for it, is it non-existent?
what do i have to do to get it wired up?
You don't have to wire the connector it should be there. Its usually just tucked very well up near the top of the dashboard near to the support bar that comes across the back of the dash. I had to cut and extend the wires to get mine to reach the sensor on the pedal. You will however need to run the NLTS wire as per instructions that came with ecmlink.
