Red Line Assembly Lube
PrimerPLus
1,160
20
Jul 28, 2011
Tokyo, Asia
Is one or the other of these Red Line Assembly Lubes better than each other?
There is a 4oz container that is not liquid and then there is this 12oz bottle that is liquid but still says for engine assembly.
Which of these should I grab? Rebuilding engine very shortly from bottom to top.
[ame="http://www.amazon.com/Red-Line-80312-Assembly-Lube/dp/B002INU8CM/ref=lh_ni_t?ie=UTF8&psc=1&smid=ATVPDKIKX0DER"]http://www.amazon.com/Red-Line-80312-Assembly-Lube/dp/B002INU8CM/ref=lh_ni_t?ie=UTF8&psc=1&smid=ATVPDKIKX0DER[/ame]
[ame]http://www.amazon.com/Red-Line-80319-Liquid-Assembly/dp/B0068FWM70/ref=sr_1_1?ie=UTF8&qid=1378505482&sr=8-1&keywords=Red+Line+80319+Liquid+Assembly+Lube[/ame]
30wt motor oil.... That's what I use, crank bearings, cylinder bores, rings, pistons
ARP lube for ARP fastners
Crane moly lube for flat cams (4g63 do not have them)
White grease on the inside of seals, cam seals, rear main, any other lip seal
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
