MorrisonFab
Supporting Vendor
- 357
- 1,376
- May 28, 2017
Johnson Creek,
Wisconsin
Not a DSM, but very relevant for anyone wondering about the power differences between the two when boost is cranked and the turbo is near maxed out!
Back-to-back dyno: Recirculated wastegate vs open dumptube, highest boost setting
The goal was to see if a well sorted recirculated setup will make the same all-in power across the board, highest boost being a key factor.
Tylor’s 2.0L Evo 9 with a HPT 6466, 1.07A/R v-band, MF v-band manifold with either recirculated O2 housing or O2 housing with dumptube, 44mm MVR, 3” MF downpipe, 3” to 3.5” ETS catback exhaust. E85, tested and tuned on Haltech by Roni at SpeedLab.Inc
All pulls were at the highest boost setting in the 850whp range (~46psi).
3 first runs/traces with the recirculated O2 housing/bend off the turbo, and 2 last traces with the O2 housing/bend using a separate dumptube.
Regardless of the setup, each trace tracks with the rest; some a little more, some a little less, but mostly run-to-run variance from slight boost differences or time sitting between pulls (which affects how much energy goes into heating the turbine housing back up vs driving the turbine etc). The dumptube setup showed a little quicker spool in one pull, and the recirc had the highest power pull, but likely mostly due to the factors above in this case since recirc isn't going to increase power, only be quieter under full boost.
Boost traces:
Ultimately, when the setup was being pushed, there was no discernable difference in the dyno graphs. When you want to max the turbo out, the power was there. More boost= less wastegate opening= less potential difference.
This was only the initial test though, added in just after dialing in the new setup on the dyno, with more back-to-back testing planned at lower boost levels where differences between the two configurations are more likely, due to the larger proportion of exhaust gas being bypassed through the wastegate. When the wastegate opens near target boost on a recirculated setup, all of the bypassed exhaust gets re-entered into the main exhaust whereas the open dumptube takes a little load off the main exhaust, essentially acting like a larger exhaust overall. These tests at the highest boost setting have the highest total exhaust flow, but the smallest proportion of wastegated exhaust flow, keeping the differences between where the bypassed exhaust goes negligible. The lower amount of exhaust being bypassed/wastegated around the turbo is exactly what increases/maintains boost to begin with (wastegate nearly closed).
The setup made 900whp with some more boost, so near maxed out in this comparison with boost still falling at high rpm. Some of the main factors are exhaust size (post turbo and if undersized for the potential power/flow), engine vs turbo size/efficiency which greatly affects the amount of exhaust gas that needs to be bypassed at a given power/boost level, and how the re-entry is handled into the main exhaust (the more potential losses if not done well when recirculated, mostly at lower boost).
A huge thank you to Roni and SpeedLab.Inc for doing the dyno tuning/testing and Tylor for coming to us to being with and offering his setup for testing!
So damn cool to see direct overlays and more to come!
Boost traces:
