1G Rebuilding Cam Angle Sensor
o0GuitarKid0o
1,077
179
Dec 12, 2013
Winnipeg ,MB, MB, Canada
Well a while back my black top cas started acting up and then stopped working around 1 am in the morning and luckily I had my spare greentop cas and a timing light in my car. Lmfao An Hour later I had spark and drove home.
Fast forward 2 years and I found it in a box and decided to take a gander inside it.
I know the pin has to be pressed out but other than that what goes bad in these things ? I'd much rather run the black top as it's a digital signal and more reliable compared to the ugly greentop .
I'd like to fix it I have new a new seal for it . Did oil get in and interfere with it? Anyone ever rebuild one?
I can feel where there's obviously magnets inside for the signal guessing it's works sorta like an abs or pulse generator . The trigger plate goes over the magnet and makes a signal.
Really hard to find a blacktop cas here in Winnipeg .
Thanks.
Ps anyone know someone with a 1984 Chrysler laser XE turbo ROFL found these mud flaps at the old chrsler building before they tor it down LOL
More reliable huh?
I have used the same green top for a decade with no issues.:sneaky:
Though I would prefer a black top myself for the accuracy, not the reliability.
I have a spare black top, but have had zero issues with my green tops at all.
As for what goes bad, my guess is the pickups? Usually is see them oil fouled from a bad seal. I've taken apart a couple and had one custom machined for a project, there's not much too them. Here's pics of the shaft, bearing and seal.
Gotta agree, my green top has been thru thick and thin and is still doin its job although I always wanted a black top model too.
Nice pictures @ThunderChild .
Yeah I dont know where I heard that they aren't the best LOL my green top seems to be fine , I'll see whats going inside it and replace the seals always good to have a spare
From what I heard and found over the years, the black tops are susceptible to magnetic fields and electrical noise. It's been a while since I looked into it though.
As for changing up sensors, if it ain't broke, don't fix it. Can definitely refurbish the optical, just be extremely careful with the trigger wheel and optical sensor, they're very fragile.
So there’s another seal besides the oring? I replaced my oring and it still leaks a little. It’s the only leak I have and my ocd wants it fixed. Do you have the part number for the seal, green top?
Thanks!!
Yes there are 2 seals: the o-ring and lip seal on the shaft.
They are the same for green and black top from what I've disassembled. I dont have a p/n handy, but the pictures of the seal I posted are above in post #3 and you might be able to derive a number from that.
Edit: I think it's a 24mm OD, 14mm ID, 6mm thick double lip seal, but I'm not 100%, and not getting up RN to get calipers and dig around for a seal, haha.
Here's one option in that measurement.
https://www.avxseals.com/mobile/Product.aspx?id=38944
Edit: I think it's a 24mm OD, 14mm ID, 6mm thick double lip seal, but I'm not getting up RN to get calipers and dog around for a seal, haha.
Ok. Thanks thunderchild!!:thumb:
3am is THE best time for that. Lol
It was only midnight for me, but my bed was more comfortable at that point haha.
Just to confirm, this measurements are the correct size for the seal (just grabbed the calipers to verify) :thumb:
Liking all this info going on here, thanks !
gonna press out the pin at my buddys place and see if anything stands out . I rebuild electronics for fun LOL including 1g ecus and literally anything else you name ive done it LOL although guitar amps seem to be my main business LOL I'll try to remeber to update If I get around to it this weekend.
You’re the man thunderchild!! Thanks!!
