Rear Rotors for 2G AWD??
DSMpwr25
110
Oct 29, 2004
Gloucester, Virginia
Is there a company that makes a big rear rotor for the 2g awd? dont want a big brake kit i just want the big rotors that will fill up my 17's?? thanks for the help :thumb: :talon:
Buying performance parts for looks can get you into trouble. You'll want to look into how larger rotors (if they're available) will effect your braking. In most cases, when you change the size of your rotor, the caliper has to be changed as well. This means a big brake kit. And when you get a kit for the rear only, the brake balance is thrown off. You might just have to live with the looks of the small rotors in the back until you're ready to do it all.
Check out Power Slot rotors. They will be listed as Power Slot big brakes or Power Slot Plus brakes
From what I understand the "big brake" kit used to be AEM's, and oem replacements were Power Slot. But now both setups go under the name Power Slot.
I belive the rear rotors are 11.5" and the fronts are 12.5". A good increase over our 2g AWD stocks wich are 10 1/4 rear and 10 3/4 front
They come with a caliper bracket to use with stock calipers. The best setup for the money IMO. :thumb:
