rear AWD rotors?
jackalopeTsi
161
May 5, 2004
Bristol, Tennessee
i bought a brake package from a guy on the trader and it came with the 2 piston calipers, cross drilled and slotted rotors front and rear for a awd, and ss lines front and rear, i was wondering since my car is fwd will the rear rotors i just bought fit?
what more info is needed. all i need to know is if rear AWD rotors will fit onto the rear of a FWD
Come on people, i know someone knows this, are the rear rotors the same for both awd and fwd?
First there is no 2 pistons calipers (stock) on rear brake, it must come from the front ? or it's already an upgraded set (wilwood or...?) who knows if you don't tell ?
If you put a 2 pistons calipers with rotors that comes from front brake (big brake) you will f"/$ the bias... if it's an aftermarket set... it's another story
no they are rotors for the rear of an awd. i want to know if they will fit on the rear of my fwd. i bought the calipers for the front of my car since mine are shot. sorry about the confusion, but i thought people would assume that i was talking about rear rotors only for my question.
As far as I know, the rotors on the fwd and awd models were the same. I'm sure someone can confirm this.
It only takes a couple minutes to take the wheel off and pull the caliper. Just sit the rotors next to each other and double check. Even if you swap the FWD rotor with the AWD rotor and it doesnt fit, its like 2 seconds to change them back again.
Just go ahead and change em ;)
