Rear control arm question?
fi3ndx
70
4
Oct 5, 2013
Providence, Rhode Island
Can this end piece be changed? If so part numbers be great. If not or as an alternative can it be restored with lubricant or something?
I just bought these off a vendor here, I regret not buying them new but I'd don't want to spend another $150 or more on new ones. They honestly arent that bad other than the bushings or whatever, they are just dirty. The part you linked isn't the one I have here, I bought this control arm because it had the end links for the rear sway bar connection and my gs spyder didn't come with a rear sway so I'm adding one.
I see have you removed the ones on your car yet because they are usally rusted together and are hard to remove
Dang, wish you had posted about options of FWD 2g rear sway bar upgrades. You could have UPGRADED your rear suspension and bought all 3g Eclipse stuff since it all bolts on and it's tubular and can be found at most local junkyards for fairly cheap.
http://www.dsmtuners.com/threads/3g-upper-lower-control-arms.351043/
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 1g WTB: 4 Bolt Axle Cups.
    Looking for a set if 4 bolt axle cups for a 1g. Located in Canada.
    • blaster1812
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
