ready to put engine in bay?
2gtalonjem
66
Nov 20, 2010
Terre Haute, Indiana
Well its getting close for me to start thinking about finally putting the engine in my car. I have followed the Haynes manual and asked questions on here. I have new Wiseco pistons, eagle Rods and all new bearing. The head has been re-done. I have installed a cometic head gasket, ARP head studs. Thats the internals list. I also have a new oil pump and seal, new water pump and seals, and all new gaskets. Everything has been torqued to spec. Am I ready to install the engine yet, or is there something I have forgotten. This is the first engine I have rebuilt so I just want to make sure things are done right. This morning I am going to take off the lower timing belt cover and double check the timing marks, (I did a mock up on the lower timing cover and other things to make sure I had all the bolts) Any and all information would be very helpful. Thank you in advance.
Balanced? Your going to have to explain that one. I have had the engine bored over.002 and honed, It has good compression but I have not had it tested properly, just had one of my local dsm friends check it out.
It's a great idea to have the rotating assembly balanced during a build. It reduces the stresses put on you internals. Less stress=longer life and smoother running vehicle. When you're taking a high revving 4-cyl like ours, it's a must imho.
would I be able to "balance" my engine with every thing already installed, (alternator, fuel pump, AC compressor, ect) or do I need to take the oil pan and other things off to do this?
It has to be apart and here is a good article on how they do it if you're interested.
How to Balance an Engine
Today I took my lower TB cover off and I found I was really out of time, so I pulled my tensioner and got out my haynes manual. I did it step by step and kept getting the timing off by 1 tooth. I am doing this by myself and found it is pretty much impossible. Is there an easier way, let me know please thank you in advance. :thumb:
Timing Belt VFAQ
:thumb:
