which engine to put in mighty max
deejames76
Aug 12, 2015
columbia, South Carolina
hey everyone, i just aquired a 91 mighty max, and i m super excited because i always wanted to own one. the thing is now which motor do i put in the bay, i want a 4g63t or non turbo but they are very hard to find where i live in sc. then the 4g63 are so expensive, i been looking into drooping other types of engines into the bay but dont where exactly to look for the different swaps. if anyone could lend a hand or point in the right direction the help would be greatly appreciated................. im a newb
He has a 91 so most likely the 2.4L 4g64. If you can't afford a 4g63t then no offense I don't know if I would be wanting to turbo my truck right now. Even if your turbo your 4g64 it will still cost you a thousand or two to make it reliable and run correctly. What exactly are you asking btw, since you posted the same kind of vague question on mightyram50?
He has a 91 so most likely the 2.4L 4g64. If you can't afford a 4g63t then no offense I don't know if I would be wanting to turbo my truck right now. Even if your turbo your 4g64 it will still cost you a thousand or two to make it reliable and run correctly. What exactly are you asking btw, since you posted the same kind the truck is without an engine right now but it has been fitted with motor mounts for a v8 but I don't want to do the 8
The truck doesn't have a heart rite now it has motor mount set for a v8 but I don't want do a v8. I have been searching the web for different setups and coming up with different things .
Sr20
F20c
LS
Vq35
