Resolved Mighty Max Wiper Linkage Bushings
1985D50
10
Jun 19, 2020
Medellin, Oregon
I have the 85 Ram 50. I joined because I am looking for the subject parts. There are 4 of them 2 one size 2 another.
This is the Mighty Max that Dodge stuck a label on for a while.
I am looking for the wiper linkage bushings. Maybe I should get a picture of them? :) Back in awhile.
OK here is a picture of the linkage with on removed. I cannot tell if the one removed is broken or supposed to be 2 piece. Some of the ones I have seen online for the L200 look to be 2 piece.
Mitsubishi ASA doesn't break out the bushings for the wiper arms on those trucks, unfortunately. You might be waiting on someone who has one to chime in.
Welcome aboard, though! I keep an eye out for D50's and Mighty Max's from time to time, telling myself I'll scoop one up if I find the right one.
Just so every one know what a Mighty Max is .....
Sorry.. I copied the picture of the linkage instead of the web site .. You can read it at the top of the picture .. copy that and see if these will work for you . If not you could always steal the bushings out of these for your linkage arms... Just tryin to help..
Thank You widget master. Sorta looks right. I can only see the one angle of them. Is that off a Montero or a later model MM? Mine don't have that 3 point mount at the pivot, that came later. They have the large nut over the pivot. I dropped a double sawbuck on eBay for a pair of the bigger ones. Fingers crossed. If you can get that link It might be what I want.
IDK how to close the thread. I solved my problem by buying a new to me complete linkage. $50 for the part, $35 in gas and a few hours of driving. Problem solved.
