Rogue Wires in the Engine bay
kidmet
Supporting Member
217
21
Jul 23, 2012
Aurora, Colorado
Any idea what these are and where they go? In the engine bay, left of engine pretty deep down in there. (Hate getting someone else's crappy project!) You can see I've been working on this a couple years.
Cam Shaft Position Sensor?
Could you post some more pictures? I'll locate these wires in my car and tell you where they go. I have a 98GSX
I would have to agree. +1
Look to be the right colors and in the correct place. They also appear to be stock wires so not someone's add on.
I take it the car doesn't run?
Car is not running, but I haven't tried to fire it up yet. A few more things to do before I get to it. I replaced the rear main seal and was running before. Just don't remember if these wires were rogue before. It's been a bit before I have worked on it (winter in CO). As I remember, I feel like the CAS was rewired a different way. Is that possible? I have everything basically back together. I have to finish my exhaust gaskets and finish wiring the oil cooler/gauge. Which I need to research more.
CAS was right, the old owner put a 1G CAS on and I needed the blue wire for rewiring. Got her all wired and she started right up. I have oil pressure. I just need to tighten everything up and put her back together. Getting very close now.
