loud air noise in the back of my engine bay
Is the vacuum line for your brake booster good to go? That is the only thing I can think of back there.
And a massive leak would cause your car to be hard to start and run like crap once it did.
So it make sense.
Okay, but as far as the noise that you're describing is concerned: Have you looked near the back of the intake? That's what I could imagine would be the source of the "air" noise you're hearing near the driver's side. Other than that, make sure the line for the PCV is connected..and there's also one more line running from the actual IM, two in the front, one in the rear. Then of course you have the ones on top of the throttle body..but that's closer to the passenger side.
yeah i could see it being that um would that cause it to make the air shoot out as different pistons are firing??
and i know the breaks arent working too well but i thought that might be because i havent put my new ebreak cables in yet
Your vacuum brake booster is leaking, that more than likely is the cause of poor braking and the vacuum leak as well.
Air is shooting out? That's not physically possible with your vehicle at idle WTF!!, though you may have the noise confused. A vacuum leak of different sizes can sound like air is being forced out when it really is just in a vacuum to different people. If you feel that your brakes require a heavier effort than normal than it more than likely is the brake booster line/fitting. Here's a way for you to determine whether or not your booster is working properly: let the car run for a minute or so, stop the engine, go in and depress the brake pedal several times, pedal effort should increase and the pedal travel should decrease. If it doesn't do that, either A: your brake booster is no good, or B: the vacuum source for the brake booster is not there (unplugged, cracked or damaged line.)
As dumb as it sounds, it could also be the wrong intake manifold gasket. My gasket kit came with a intake gasket for a 6 bolt when I was assembling my 7 bolt... I didnt notice until I fired the car up that it had a HUGE leak there.
Do you have a 7 bolt intake manifold? If you do then that is the gasket you need.
7 bolt head + 7 bolt intake manifold = 7 bolt intake gasket.
It is not your pistons shooting air out.
What the hell is a vacuum booster?
This is simple.
Go out to your car and look at it. Check and see if the big ####ing hose coming out of your brake booster is attached to the intake manifold. If it isn't then you will have a big ass leak.
