Bad wires or coil pack when engine bay hot?
JMiller
684
Jun 30, 2007
Irmo, South Carolina
Ok, when my engine bay gets warm/hot (from cruising at 3500rpm for 2 hours) and i go WOT as soon as it sees boost it starts stuttering really bad, but once the car sits overnight its good again. So i was wondering If the plug wires or coil pack was to blame. I checked my plugs(BPR7ES) and they looked great, all gapped at .28. Any help would be great cause i can only get wires or a coil pack this week before i go back.
Thanks :dsm:
Coil pack or transistor pack most likely.
My 1g did the same thing and it ended up being the CAS...it would actually shut the car off sometimes. Another car just misfired that way and ended up being the coil pack, also seen bad transistor pack do the same.
Was just messing with the car and i could not find the transistor pack, could someone post a picture of it. Also i don't seem to have a redline at idle anymore i have done nothing to the ecu and i got it to 7800rpm.
Once again thanks for the help.
Really?, ok thanks.
This thing?
Also could someone post a list of all the cars i can get a transistor from that will work with my car, cause I'm going to pull a part and taking(buying) everyone i can find.
