kyler021
- 247
- 189
- Aug 29, 2023
Pasadena,
Maryland
So, as the title states none of my cooling fans will turn on.
I’ve replaced the temp sender, temp sensor, thermostat, and radiator cap.
There’s 5V and ground at the connector for the temp sensor. I’ve tested the relays in the fuse box, all of them click when given 12V power and as far as I know all of them measure out correctly in terms of resistance.
All the fuses look good, no breaks in them. I did replace the 30a fusible link as the insides were melted.
When we unplug the coolant temp sensor while the car is running, both of the fans turn on full power. When the temp sensor is plugged in, with the ac switch on in the cabin, the ac fan does not turn on. I’m planning on hooking up a scan tool to it tomorrow to monitor coolant temp while it’s on and see if the fan comes on at the specified temp that the manual says.
The AC belt is not connected up on the pulley side, but I don't think that would cause this.
Is there any other tests I should run? I feel like I’m missing something very simple. All the connectors are snapped in to my knowledge. Thanks for the help!
Kyle
Kyle
