spyderdrifter
- 5,430
- 862
- Jul 11, 2009
Somewhere in,
Colorado
So today at work, things are slow. I brought my spyder in to put my Mishimoto radiator back in. I got everything in and started the burping process with the funnel that connects to the rad cap. I had it running for at least 45 minutes and still nothing with my fans. They won't turn on. I had this exact issue last summer and that's when I put my OEM one back in. Had no problems with the fans after that. But again, they're not coming on with the aluminum rad. So I decided to turn it off, cap everything up and fill the overflow res. Then I restarted my car. After a few minutes, the overflow just about overflowed like the t-stat isn't opening. I know it works.
Could the fans not be coming on because it's an aluminum rad? What could cause the overflow issue?
I know the car is warmed up, according to the gauge which is fed from a sensor I bought new last summer. Likewise with the ECT sensor.
Edit: As of just posting this, my rad fan came on. Does it just take longer because of the upgraded rad?
So now that the fan is cycling on and off, the over flow res keeps filling up over and over after I drain it. What the heck does that mean??
