JusMX141
Moderator
- 15,147
- 1,289
- Dec 13, 2005
Greensburg,
Pennsylvania
Any one for a T3 Garrett with a 360* thrust plate.
. 8/12 blade 54mm/83mm compressor. There is no shaft play and the wheels look good to my eyes, but I had a couple questions. First off there seems to be some chips along the bottom of the wheel, but they look like their supposed to be there.
I've put coke, viniger, wd40, pb blaster around the ring to eat away at the rust. I've given it some love taps with the dead blow hammer but it still won't budge. How do you suggest I get this off? Should I try heating it up? Dunking it in some sort of solvent? This brings me to my final questions. I will be rebuilding this turbo and wanted to know if I need to mark it for balancing purposes? Also what is the best way to clean all the components? I have a parts washer and media blaster cabinet but unsure of which solvents and media work best.I got a call the other day.The dsmer had bov flutter after installing hard piping.Why did this happen?
I don't know, I wasn't there.I got a call the other day.The dsmer had bov flutter after installing hard piping.Why did this happen?
Plain old Garrett T04E50. Probably a .63 a/r T3 turbine housing- about as common as it gets.
So this question may be a little out of the ordinary, but I was hoping maybe you had some input on this.
Question: I'm building a mechanical system to actuate the vanes on a Holset HE351vgt I picked up. From my understanding, this turbo will largely decrease spool time while still performing like a larger turbo, given vane position is actuated correctly. I want to actuate vane position based largely on boost pressure, as well as RPM and TPS (more specifically WOT) signals all combined. The problem is, idk at what boost pressure and RPM would be a good start point? Is this pretty much going to be a guess and check thing, or can you take a stab at what I'm getting at. Or, is this a shitty idea all together? And, if this is a shitty idea all together, what are your suggestions on what signals to use to best actuate the vanes with a mechanical system? This system could be made using a vacuum wastegate actuator, a few Hobbs pressure switches and TPS and RPM trigger switches. I'm just looking for a simple mechanical solution for vane actuation, and the best signal to base the actuation off of.
I have been doing a lot of research on how the control system works. The problem is, Most of the info I am finding is for VGT operation on diesel engines. The way they were designed to work on the Diesel engines they are equip on, and they way they work for us have some differences from what I'm reading. For example, incorrect vane position on a diesel engine could mess up fuel economy and emissions control, where as on our smaller displacement gas engines this isn't really an issue. The diesel engines also use the vane position as a way to limit boost, where we would still have to run external wastegates. These are just a few examples of what the differences are between engines. I know the basics, and also know that not only does optimal vane position vary by each particular setup, but there are many factors that determine the optimal vane position for a given time. I'm not looking for a lesson in how VGT turbos work, but more of a simple breakdown on what largest factors that contribute to optimal vane position on OUR small 4cyl engine are, and how they can be figured out. From my understanding, the largest benefit to running a VGT turbo on our engines is a quick spool up time. If that's the case, couldn't you just make a simple mechanical system that uses boost as a signal to determine when the vanes start to open? You could also incorporate a RPM and TPS signal into this to further fine tune when the vanes open, but it would still be pretty simple. I appreciate any help you can give me. Thanks in advance.
