turboglenn
- 6,375
- 124
- Nov 5, 2007
RIpley,
West Virginia
Just..would apreciate it if you could use your vast turbo part number knowledge to gimme the specs on the one i just bought
it's a PTE6776RS T3 .63a/r hot housing/ts04 cold housing, BB center cartreidge..all i know is the first part "67" is the mm diameter of inducer side of compressor wheel and the last 76 was uxhaust trim (nimor divided by major OD's)
but i don't know what that all equates to as far as compared to the old P-trim t3 Q-trim t4 turbines etc..
and what is the major diameter of the cold wheel or is THAT the first "67" part?
der went to the trusty google and found it but it's not on PTE's site that i can find said:Part Number: PT6776R
the "S" at the end of mine means the tS04 cover (this spec is to4E cover)
Max Rated HP: 750 (i was told 1125 CFM by a PTE rep on the phone a few days ago)
Inlet/Outlet Size: 3"/2" 4"/2.5" or 4"/3"mine is the 4" inlet 2.5 outlet
Bearing System: Ball Bearing (not sure if this is their replaceable cartidge or not)
Garrett Compressor Wheel Trim: 63
Garrett Turbine Wheel Trim: 76
Garrett Compressor Wheel Specs:
Wheel Trim: 64
Wheel Inducer: 2.620" (67mm)
Wheel Exducer: 3.310" (84mm) (wow dats big!!)
Garrett Turbine Wheel Specs:
Wheel Trim: 76
Wheel Inducer: 2.920" (74mm)
Wheel Exducer: 2.542" (64.5mm)
