putting a 14b on a 2g engine
Yes it will work.
The oil feed line you can use by feeding it off the head on the 2g but you will have to block the oil flow from the OFH by either cutting and shutting closed the old oil feed line or screwing in a npt thread on the old oil port hole where it fed from.
As for the coolant lines, the top coolant line will work fine with a little bending and a custom hose, the bottom one you will have to bend it to have it face a little downward and then use a extended piece of hose to run it back to the t-stat housing.
Hope this helps.
