Spoolin4Ever
- 1,142
- 15
- Apr 24, 2005
Moses Lake,
Washington
I have a burned valve in cylinder number whatever is closest to the driver's side.
I want to pull the head, leaving the cam gears and cams on there just because it's a pain to keep it all seperate for me as I have no room to work and am a newbie in this area.
I want to know the basic list of steps for pulling the head, and being able to change the timing belt, tensioner and water pump all at the same time. And I have a couple of questions.
1. Is there a way to keep it staying in time or will it try to turn on me? I mean when I pull the head off with the timing gears, I have no way of strpping with zip ties or a binder clip? Or is there something else I can clip on to besides the cam gear to keep it in time?
2. At what point should a zip tie or binder clip the belt?
3. At what point should I replace the tensioner? And water pump, timing belt?
So I am in need of a quick and dirty faq on a head removal and replacement with a new timing belt, tensioner, and water pump.
I printed the timing belt TSB, and a head removal FAQ with pics. BUt the TSB re-uses the tensionser, I am replacing it. So it's a little different.
