BC280 cams stock head and gears?
It is highly recommended to run aftermarket spring with these cams because of the lift. I currently have a set of bc280's in my motor that's waiting to go into the car with kiggly behive springs. 280's are for a higher rev powerband and stoking springs will more than likely float up there. Springs aren't that much. Pm me if you want a set of HKS springs from my last built.
You should really install some springs, The BC1100 should work just fine with the BC cams.
Just make sure the springs you run are set up properly.
  • Wanted 6 bolt NT water pipe
    • chrisman287
