Proper Injectors with 20G
kiri
41
Feb 6, 2012
clarksville, Tennessee
What would be the best injectors to run with:
95 Talon Tsi Awd, 20G, 255lph, FMIC, gauges, Safc, mbc, turbo headers, external wastegate
the reason I got a 20G was because it was $100 and by stock turbo took a dump on me and the wastegate locked up or whatever.
any feedback I would appreciate
I would say 750 or 850 with that turbo, to be safe, the safc has its limits i think 650cc for your fuel is as high it goes. With link any size inectors you can run. My 1g has a 18g and im upgrading to 850s or higher this spring.
So what I am getting from the comments is I need a DsmLink and a good wideband 02 sensor..... and then I can run 800 ish cc injectors for optimum power?
And.
If I get a DsmLink is my Safc II useless?
If you have plans for E85 or E98m then go with some 1150cc.
Stupid question.. But what is E85 or E98m mean? Also what does FIC or PTE mean inregards to injectors.
E85 and so on is Ethanol, you use a lot more of it in a fuel mixture so a larger injector is required. You can run a bigger injector like a 1200cc just to be safe should you choose to run ethanol in the future and that size will still be fine for pump gas, albeit a little overkill.
FIC= fuel injector clinic
PTE= precision turbo engineering.
Both make reliable injectors, i personally use PTE 1200's and install mostly PTE's when given the option.
I should feel confident in a setup with pte 880's,20G, external wastegate,255,FMIC,MBC, and a dsmlink to tune it?
If I am dragging this thread on please tell me because I am still new to the forums and am still learning all the rules.
Thanks for all the advice and yes I plan to sell the Safc since I need to buy a dsmlink now.
