toomey200
- 161
- 3
- May 31, 2006
Mountainside,
New Jersey
could i run 550cc injectors with a 20g turbo and a walbro 255 fuel pump and not have to worry about fuel cut problems at high rpms with an AFC?
awdrst said:I ran 24 psi on my 20g with 650's on pump gas. My IDC's were right around 83%.
andymoraitis said:If you plan on controlling your injectors with something like DSM Link or an EPROM ECU with a Keydiver Chip, go as large as you like. If you'll be running the AFC, you'd be better of with a max of 650's. People have tuned 720's on an AFC, but the timing curves get way out of whack from the airflow correction and you won't be able to run as much boost on pump gas as a result. Even with 650's, you'll be chasing your tail trying to get the right balance to keep knock away.
Hope that helps,
Andy
andymoraitis said:To sum it up, using an AFC to tune is like trying to hammer a nail with a tree stump.
.....andymoraitis said:Also, the stock boost gauge will be able to read knock, so although you can keep the logger, you'd now be able to see up to 15 counts in real time instead of waiting to pull data at the end of the run.
