20G what size injectors?
my98gsx
Supporting VIP
794
290
Aug 14, 2005
Wappingers, New York
I have been searching for the perfict turbo for a long time and i feel that the 20G is the best for what i want... running a 20G no more than 15lbs what size injectors should i get? 550's? or 660's? and if anyone has a 20G on thier car please tell me what you think about it... everyone i know has a 16G and they say go do a 20G because they all want a little more then the 16G produces. And since my car is AWD i thought a 20G would be fine for the street.
What are you going to use to tune your injectors with?
If you are going to tune with DSMLink, you might as well get the biggest injectors you can afford, 680cc or bigger. Some might even reccomend 720cc or bigger.
With DSMLink you can tune 1600cc injectors and have a nice stock 750rpm idle.
Even at 15p.s.i., the 20G is flowing A LOT of air. It will require more fuel then a 16G at 15p.s.i.
Its going to be very hard to tune 660cc+ injectors with your safc. I suggest you get something bigger like Droopy209 said. If you have the money buy a Dsmlink setup. However if you dont, id go with some used 660's. Then after some saving upgrade to Dsmlink, sell your injectors for the same price you bought them for and buy some bigger injectors so you can turn the boost up even more (without maxing out the 660's) and see the true power of that 20g.
