what size injectors?
You have ECMLink... go as big as you can afford to leave room for future plans.
If you go above 1450's, there is some discussion (or debate) as to whether you need a driver box or not. I hear the new FIC 2150's are excellent drop-ins, although they are pricey.
I am currently running FIC 1250 Blue Max's, and they are excellent as well.
wow i should probably go with 1000's or around there then right? you have way more mods than me. Those blues are kind of pricey too arent they? Are pte's any good?
I agree, go with something larger that way in the future if you decide to go E85, there won't be much to change for you. Might as well make one buy instead of upgrading a couple times. It will be cheaper in the long run as you can just re-tune with ECMLink.
I'd vote for FIC only because when I researched they were the top injector. If you have any plans of going with high boost or upgrading to a large turbo or even E85 then go with a large sized injector. At least a 1250cc injector to be safe and it's not much more costly either. It's better to have extra than not enough and have to buy again.
I have just updated my mods and im trying to find out what size injectors im going to need.... i plan on runnin on 91 octane and my goal is atleast 400whp. Also which kind and what brand would you guys recommend???
I would say anything from 850's to 1250's. I am personally using and would recommend Fuel Injector Clinic injectors. With ECMlink you can completely control your injectors so there really is no such thing as too big like everyone is mentioning. Check out this thread for more into on how to calculate which size injectors you would "need" for your application: http://www.dsmtuners.com/forums/newbie-forum/393264-x-hp-fuel-injectors.html
The spray from FIC injectors is a lot wider and more fine(for lack of a better word), and allow for a more efficient combustion. FIC is easily one of the(if not the best) injector supplier around.
I would go with 1050's if I were you.
