Products the DSM crowd would like to see made
I don't know why you quoted me, but while I know about this and it is a great product it really isn't suspension.
I'll break it down for you, Front control arms, K-member, rear subframe. I already have replacements for the rear arms.
I'm just trying to let people know what products are available. Especially ones that are built by fellow members.
^^ There's your product...a plug! (I need one...my plug is ghettotastic)
So put a sink drain plug in the antenna hole?! Thats going to look so crappy, and blatantly visible, i'd much rather have a shorty antenna. I could bondo over the hole... then again that's a bit permanent.
I see this product come up when I search for an antenna.
Any input on it, how good it works or its quality?
What are we supposed to put in the hole that'll be there (thats what she said) once the antenna is gone?
You just get a rubber grommet to fill the hole.
Its not uncommon to see plugs on cars. Its much better then the unsightly antenna that we have.
Just the same with any hole that you don't want there; you fill it. All of mine are welded shut. Bondo is another option. And a plug is the most affordable and least time consuming solution.
I've installed a few in friend's cars, and it's always worked great. No complaints from me or them. If I ever listened to the FM radio in any of my DSMs, I'd be using one.
Text and sarcasm are mortal enemies. Throw me an emoticon, homie.
Thats good enough for me. Looks like I'll be trying it out.
better quality fitment for carbon fiber fenders dont line up with the door good and both front tips broke off of mine and getting it over the side lip just makes them crack like crazy. Then vis ram air hood didn't line up with my latch and now I have cracks in the front from shutting it and at 120mph ram air was flexing and caused to spider web
damn. sorry to hear that. I had cf fenders on my two eclipses from 2006-2008 with zero issues.
im not sure if they are out there or not but havent seen um so i would like to see metal door handles for a 2g they are always breaking and the ones from a parthouse are even crappier
Back when I had my Avenger, someone on ASEC made aluminum door handles for the Avenger. Am I right in assuming they would fit a 2G?
Id like feedback on this idea...
I thought I've seen timing and balance shaft case cover in sheetmetal instead of plastic? or it might have just been a really worn out one made out of plastic but it looked like sheetmetal to me.
only reason I was even thinkin of it is cause I need one LOL my plasic one cracked in so many areas, and I believe its what caused my balance shaft belt(of 3 months old) to snap! my timing belt was next to go, it also has grinding wear on that... whew! got lucky
