1G One headlight is dim
TGST90
113
Nov 28, 2010
Houston, Texas
My passenger side headlight is dim because the wiring that connect to the back of the headlight are about to break because of the headlight popping up and going down so many times. What could I do or use to fix my wiring on the connector?
I would unwrap it,(make sure you have some e-tape first) check the condition of the wires, if there's any splicing or cuts in the wires then either re splice it or just replace the wires.
