lights go dim as speed increases
chrit
Jan 28, 2011
seabrook, New Hampshire
I have a 1995 eclipse gs and as i go faster say 70mph my dash lights go dim and near 85 then are burnt orange color but when i slow down they brighten up alot. could this be my alternator? and ive also have the stuttering 4k rpm problum like a few others on here and when i spray carb cleaner into my throttle body my car acts completly fine untill a few days later then it goes back to kicking/bogging how do you clean out a intake manifold without taking it off?
First problem definitely sounds like the alternator. The regulator inside is probably bad. I would replace with a new one. Depending on how much you are willing to spend I would go with an OEM unit.
Tony
1995 Eagle Talon TSi AWD
1996 Eagle Talon TSi AWD
def, sounds like an alternator problem. replace that and if the kicking/bogging still continues then i would be looking into a fuel map sensor. i had one go out on my 96 gs without throwing a code. i replaced everything but that untill someone said something.
You could always check the voltage at the battery with the engine running to see what kind of voltage your alternator is putting out. I would be looking for at least 13.5 volts.;)
I would check alternator voltage at the same time. If lights are going dim your dropping below 11-12 volts under load. Or your just traveling as fast as i do (close to the speed of light and your going faster than your headlights ) LOL :)
