2G Oil pan level sensor
EclipseGS1996
51
7
Mar 27, 2022
Luxembourg, Idaho
Hello, I would like to know if a Oil pan level sensor from a Evo 9 would fit in my Eclipse 2g with a 4g63. Would this work or would it indicate me a false oil level because the oil level is not the same on a Evo 9? Because my oil level sensor is not good anymore.
Thank You
Its a sensor to detect fluid. It doesn't matter what car it is as the sensor type is not differing on level of placement ONLY when its uncovered / likely resistance based
Where on the 1G/2G were you thinking to put the sensor? Isn't the Evo 9 transverse in the engine bay, and the Evo 9 oil pan turbo drain and other features are incompatible with the Evo 1-3 DSM 1G/2G stuff?
Its a sensor to detect fluid. It dont matter what car it is as the sensor type is not differing on level of placement ONLY when its uncovered / likely resistance based
Would this part then fit on my Eclipse? Because it looks the same but it’s not listed for a Eclipse😅 It should be MD302295 but this one is MD302293
Looks similar, not sure if its a part number revision or resistance inside but check what cars they fit. I have one of these pans from a Galant with the sensor in so check what one works on a Galant and opt for that one
Looks similar, not sure if its a part number revision or resistance inside but check what cars they fit. I have one of these pans from a galant with the sensor in so check what one works on a galant and opt for that one
Okay I just found that this one works on a Galant with 2.0 engine so this must be ok.
Thank you very much🙂
Nice - If it comes in a 6Bolt version - I'd get this.
I'm not sure if they were sold there or over this side on the 6 bolt, 7 bolt for sure but don't recall the 6 bolt 1G being sold that early on. My 1gb is an import from the US but same non turbo 4g63 and 6 bolt. I would have to google when the 1g's started to sell in Europe.
Hello, I would like to know if there is any way to delete the oil pan level sensor because I cannot find one to replace. So now I would like to just delete it and make the oil light go away.
Thank you
If plugging it removes the sensor then leaving it in place and un plugging it surely does the same thing does it not. Free plug and as simple as disconnecting the connector.
There's a what now? I had no idea.
His Eclipse may be European.
Should inspect the circuit first. Maybe the problem is something else.
Couldn't you just pull the cluster light?
I would like to delete it without removing the cluster light.😅
If I remove the sensor it will leave the circuit open and the light will stay on
Looks like you can just put a jumper wire on the connector and that should turn off the lamp.
I will try a jumper wire if this works than it will be good.😁
@EclipseGS1996 Please upload a pic of the sensor. Don't you see any mark or numbers on it? Since this sensor was not originally equipped in the US or Japan, Mitsubishi may have used a sensor from other manufacturers, such as Mazda, Toyota, Nissan etc. They shared many same sensors. If so, perhaps the sensor is not discontinued yet or still replacement is available.
He already knows this info and has another thread on it all (merged now)
It’s a Mitsubishi Part and it’s equiped on the European Eclipses with the 4g63 N/A. Part number is MD302295.
He already know this info and has another thread on it all
I see. You have already told him.
It’s a Mitsubishi Part and it’s equiped on the european eclipses with the 4g63 N/A. Part number is
You didn't get my point. Many sensors are shared between different manufacturers by putting it on their own part number and package. So maybe you would be able to find the same part from a different manufacturer car. That's what I meant and why I recommended you to check some mark or numbers on it.
Anyways you already have the diagram, just do what you need.
