TasosEclipse
- 129
- 4
- Oct 20, 2016
Thiva,
Europe
I have a 4g63 stroker and I can't find where the oil leak is. When I press the gas hard a smoke appears from the exhaust. I checked the compression 175 across all 4. I changed to a new turbo I changed the valve seals. I checked the crankcase pressure -0.2 bar to 0 bar when in boost and the car still leaks, what else I have to check? The car has Evo 8 oil filter with oil cooler.
Thank you
Here is a picture from the engine.
Thank you
happened to me too
