- Thread starter
- #51
TasosEclipse
- 129
- 4
- Oct 20, 2016
Thiva,
Europe
Here is a photo from the head
Goes to atmosphere? It doesn't connect to anywhere on inlet to the turbo?The pcv goes to intake like stock and the other one goes to atmosphere
Okay and what about the other line with the check valve? You'll have to take it off and blow through it from the valve cover side and it should go through. Then blow through the other side and make sure it DOESNT go through. It's only meant to let vent crankcase pressure into the intake manifold but keep boost pressure from pressurizing the crank case.
Okay so if your check valve is fine and your other line doesn't go anywhere.. the only sources of oil to your intercooler pipes would be your turbo.I checked the valve it moves like you said
Well that's fine if that works but it looks kinked or like it goes below the oil pan drain hole, and then comes back up. Oil won't drain properly if it's that way. The oil in the drain is mostly gravity drained so if it's not a good ALL DOWNHILL drain you're probably going to have drain issues.I use the stock return line on the pan
Red line is the oil drain. See on the left it goes BELOW the port on the oil pan? That's bad.I use the stock return line on the pan
I think we need a better picture of the drain line to see for sure.Its like the good one it’s going like the bad one
I'd say this is almost 100% likely your problemOk I will fix it. you suggest this is the problem ?
