Anfurnyy
Supporting Member
- 1,492
- 1,910
- Jul 4, 2020
Rapid City,
South Dakota
Installing a wideband in my 93 1g, went to check out the o2 input on the ECU harness and saw this mess. Doing some research I understand that this has kind of been covered in other forums and that this is actually OEM this way?
I drew a diagram and just need to know if this is the correct way this is supposed to be? And if so where do the two black wires (grounds?) Go to back inside the harness. Aren't they supposed to go to the sensor grounds on the ecu since they're sensors?
