Cel code. O2 sensor. Wideband.
b00zt3d spyd3r
585
452
Feb 25, 2016
Lawton, Oklahoma
Okay I've had a cel light and code p0135. I now know that the wires to the o2 sensor were cut and sensor removed, and a wide and in its place. So my question is. Can I replace that oo2 sensor and plug it into the stock plug to get rid of cel? And where would I need a new bung welded in for wideband?
Does your wideband have a narrowband sim built in it? And yes you could wire the stock o2 back in and have it work and get rid of cell. Is your wb wired into the ecu? The best places for the wb bung are in o2 housing or after flex section in downpipe. Just make sure to weld it at the proper angle.
yes it has a narrow band wire. It is not wired to ecu. It already has o2 sensors in both the o2 housing and exhaust. I figure replace the original o2 sensor and add another bung and be good to go. Thanks!
Not to hijack this thread but... I have my Innovative wideband wired into the ecu but its in the exhaust, the oem o2 sensor is in the o2 housing but I believe it may need to be replaced... I plan on getting my car tuned with link this week and was wondering would the oem sensor need to be replaced with a new one?
I probably would replace if it's bad to make sure you get accurate readings and what not
