WES_393
DSM Wiseman
- 3,814
- 98
- Jun 6, 2011
Colo Spgs,
Colorado
Hey guys, I've been attempting to idle tune recently and have gotten nowhere since my front O2 constantly reads .08 volts. I though it was strange since I just installed an OEM O2 sensor. So I started looking at the wires and found this mess.
There are three white wires going into green sheeths. These wires go to pins 75, 76, and 78 which is Front O2, Rear O2, and Knock Sensor. There are also 5 black wires (one of which is pin 92 Sensor Ground) that are coming from the wiring harness, through the green sheeths, and then the all of the black wires are soldered back to the sheilding inside the sheeths! There is no way this is stock or even okay to leave alone especially since I'm gettin near zero O2 sensor voltage.
So my question is, what do I do with these ground wires? Can I just ground them to the chassis or do they have to be grounded to the ECU? If so, how do I know where each one should go pin wise? There is only a few ground inputs on the ECU, none of which are missing or cut, and what looks like at least 3 stock ground wires that clearly need a better connection.
Any help is appreciated!
BTW these green sheeths go all the way through the wiring harness so even after removing a few feet of shrink wrap I can't find where it ends.
) Thanks for the help MJ!
And no problem Wes glad to help out.
